Database Import - CMS 1.8.11 - Custom Installation
I have a problem importing a previously exported database. In the database.tar.gz the two files data.dump and structure.dump exist and the content looks OK.
I get the following message.
Best regards
Hubert
Thank you for bringing this to our attention, there is a bug with the Import functionality. Below is a link to the logged issue:
You can still upload the backup manually, you will need to import the database directly into your MySQL server. Please note that you will also need to restore your CMS Library to a backup from around the same time as the database you want to upload. If your backup is from a different CMS, remember to adjust the library path, as it will not match this CMS.
