CMS: 3.0.2
We’re working to pull in data from Solarwinds to display graphs and info. One manual change I had to do is import the certificate to curtl-ca-bundle.crt, as solarwinds uses a self-signed cert for the API calls.
I created a new dataset, created the columns and ran the task to get data. It was very fiddly to get it to that point, with the data not populating when choosing a data root. At some point, the stars aligned, data flowed and the world was great.
Then I changed the URL to get more data, adding appropriate columns. Now I have no data imported, the Test Data URL doesn’t display anything. If I run curl from the server itself, I see data displayed. If I run wireshark and run the dataset task from the client, I see data in wireshark, so I know the call is being made and something is coming back.
I tried creating a new dataset, but experience the same results. This looks like it could really show some neat info, if I could only get it to work consistently. Ideas?
