Hi
I have been working for the last week on version 1.8.2 on a Docker running on 2008r2, everything has been working very well until…
I seemed to have a problem with XMR so decided to reboot the host, now I have lost all data and the CMS is completly reset, I have found a few other posts with this same issue and none of the fixes have worked. It’s like everything has dissapeared, there is no shared folder under the Xibo directory.
Any assistance is much appreciated, I’ve lost a lot of work!
Here’s my running config:
$ docker-compose config
services:
cms-db:
environment:
CMS_SERVER_NAME: cms.example.org
CMS_SMTP_FROM_LINE_OVERRIDE: "YES"
CMS_SMTP_HOSTNAME: gmail.com
CMS_SMTP_PASSWORD: yourpassword
CMS_SMTP_REWRITE_DOMAIN: gmail.com
CMS_SMTP_SERVER: smtp.gmail.com:587
CMS_SMTP_USERNAME: youraccount@gmail.com
CMS_SMTP_USE_STARTTLS: "YES"
CMS_SMTP_USE_TLS: "YES"
MYSQL_DATABASE: cms
MYSQL_PASSWORD: *********
MYSQL_RANDOM_ROOT_PASSWORD: "yes"
MYSQL_USER: cms
image: mysql:5.6
mem_limit: 1g
restart: always
volumes:
- /c/users/xibo/shared/db:/var/lib/mysql:rw
cms-web:
environment:
XMR_HOST: cms-xmr
image: xibosignage/xibo-cms:release_1.8.2
links:
- cms-db:mysql
- cms-xmr:50001
mem_limit: 1g
ports:
- 80:80/tcp
restart: always
volumes:
- /c/users/xibo/shared/cms/custom:/var/www/cms/custom:rw
- /c/users/xibo/shared/backup:/var/www/backup:rw
- /c/users/xibo/shared/cms/web/theme/custom:/var/www/cms/web/theme/custom:rw
- /c/users/xibo/shared/cms/library:/var/www/cms/library:rw
- /c/users/xibo/shared/cms/web/userscripts:/var/www/cms/web/userscripts:rw
cms-xmr:
environment:
MYSQL_PASSWORD: **********
image: xibosignage/xibo-xmr:release_1.8.2
mem_limit: 256m
ports:
- 9505:9505/tcp
restart: always
version: ‘2.1’
