DarkSky Weather vs. Display Status
More a general question or request for confirmation:
I have layout scheduled to some displays which is showing actual weather with Module “Weather Powered by DarkSky”. It is running perfectly well. Only thing what is disturbing is, that all screens are mostly showing the cloud icon state (Player has not logged in with content waiting to be downloaded).
We’ve set the caching time in the module to 3600 seconds (1hour).
Update Interval of module inside layout is set to 60minutes.
I can see in display overview, that all displays log in every hour to pull an update. I cross-checked, that this is due to the updated weather layout. Some seconds later the line in the display overview becomes green beause layout is up to date. Some minutes later line is yellow again with cloud icon status. I assume because weather state has changed in the meantime and therefore an update is present for the display to pull.
Am I correct here?
Best
Daniel
Best
Daniel
What you’ve put sounds plausible. If you go in to the Manage page, it will show you after the next collection happens what the Player downloaded (there will be download sizes next to the files or widgets) and that will confirm it.
