I just did a test upgrade from 1.74 tot 1.81 (docker). In my 1.74 version I used a custom theme.
Now when I try to access the 1.81 version, it tells me “Fatal Error - sorry this shouldn’t happen. The theme “mymdash” does not exist” (Where mymdash is my custom theme.)
Is there a way I can go to the default theme in my docker install ? (I know I can’t use my old theme anymore because of the new templating system.)
As I’m not fully understanding docker yet, how do I connect to mysql within the docker container ?
I installed the mysql client, but when I try to connect with “mysql -h 127.0.0.1 -P 3306 -u root -p” it tells me it can’t connect. I also tried “localhost”, but that didn’t work either.
Thank you. However I still could not connect. I solved my problem by creating a new database export, changing the setting in that database and then started the import/upgrade. Now my install is updating like it should.
