I just try to develop a custom task in Xibo 1.8.11.
I have created the following .task-File:
“name”: “My Bee Task”,
“class”: “\Xibo\Custom\Bee”,
“options”: {}
and placed it in the Xibo\Custom-Folder.
In the same folder I put the Bee.php-File.
<?php
namespace Xibo\Custom;
class Bee
/** @inheritdoc */
public function run()
$this->log->debug(‘Hello Bee’);
$this->runMessage .= __(‘Done’) . PHP_EOL . PHP_EOL;
Beside the code shown above, the file contains all functions from the TaskInterface.
If I plan and run the task, I get a NotFoundException thrown in Task.php.
If I place the files into /tasks and lib/xtr with a changed namespace (to Xibo/XTR) everything is working.
Is this behavior correct or a failure?
If it is correct, how can I create tasks using Docker?
I tested this on Windows 10 with Docker and with a manual Installation (XAMPP), both with the same result.
Regards,
Jens
