Current player plans for RPi3
The latest comments from project management on Linux/Raspberry Pi (not being a suitable client platform) seem to be about 15 months out of date, and predate the Pi 3.
Any late words on this topic?
It’s my understanding there’s a fair amount more horsepower and acceleration on the model 3…
(That I have 3 of them out, and cannot get Concerto to run to save my life has nothing at all to do with this query. :-))
Haha :smile:
We have always said that RPi is not suitable - we invested significant time trying to get it to work and it just didn’t. You are usually far better off with something specifically designed for the use-case.
That being said, we are working on an Ubuntu Player - so assuming you can get Ubuntu running on the RPi3 you could certainly try it out when its available.
For which there’s no current timeline, in consequence of which I have to eliminate Xibo from consideration, whether I’m willing to put in eval and coding labor not, then; do I understand it correctly?
Does there exist Linux client code compatible with 1.8?
Was it evaluated on a Pi3?
Yes you understand correctly - it is being actively worked on and adding additional code labour on top won’t make it happen faster. Once there is something out there as a base, then additional help would be most appreciated, whether with testing or with code.
We can’t comment on a timeline - but we’re making good progress. It is being worked on here (https://github.com/Stivius/XiboLinuxStack) which is a fork of where it will end up (https://github.com/xibosignage/xibo-linux). You are more than welcome to check it out, but it isn’t ready to try.
No and No to your last 2 questions. If you have to eliminate Xibo then i’m sorry to hear that - we can only do what we can do.
I was insufficiently clear. :slight_smile:
“There does not now exist linux code which will run against 1.8; whatever code does exist can’t be tried on the Pi3 cause it won’t talk to 1.8”, that was the question I was after. Sounds like that’s no.
You’re certainly not responsible for my timeline, no. :slight_smile:
Correct - the old Player doesn’t run against 1.8 (it only runs against 1.6), and the new Player will run on 1.8, but doesn’t actually run at all yet, because it isn’t finished :smile:
When it’s ready, it could (in theory) be run on a RPi3 with Ubuntu installed.
Thanks,
Dan
Right, ok. That’s where I thought we were.
That said, it might be productive for me to try 1.6, but that returns me to the question:
Has anyone tested the 1.6 compatible Linux player on a Pi3, which I guess is really the question I was trying to get to in the first place – sorry; it’s been an awfully long week. :slight_smile:
[ looks ]
Except that there doesn’t seem to be a way to download the older versions.
Am I missing something?
The discontinued Python Player can be found here: https://github.com/xibosignage/xibo-pyclient
The 1.6 CMS predates our use of GitHub and is available on Launchpad: https://launchpad.net/xibo/1.6/1.6.4
I doubt anyone has tested that setup on a RPi3, but anything is possible :smile:
I just saw the posting about the first-cut on this elsewhere.
I’ve just updated the relevant server to be capable of dealing with Docker, so I’ll probably get 1.8 running on it this week, after which I’ll see how the TP compiles on a Pi3.
If anything comes of it, I’ll let you know.
The posting doesn’t actually say, but I’m assuming this is all 1.8 stuff?
Yes the preview is using 1.8 CMS-origin layouts.
We won’t be actively targetting the Pi. There’s just too many issues with closed drivers and hardware specs IMO for it to be viable.
There is better hardware out there, that doesn’t have those limitations.
