Android 275
CSS don’t work properly on android player. This followes CSS works on Windows Player but not under Android :
overflow: hidden;
text-overflow: ellipsis;
display: -webkit-box;
-webkit-line-clamp: 13;
-webkit-box-orient: vertical;
It should clamp the text on 13 lines but the text appear on the entire region.
The CCS is corectly loaded because the “text-align : justify;” is applied.
Maybe a css expert can read this post and help ;).
All the best,
