Guys, I set up the Xibo Docker in Centos. I would like to create a custom theme. I assembled the XIBO not Docker and followed the tutorial
https://xibo.org.uk/docs/developer/themes
Everything went well, but in Docker you are confused, where exactly do I find the files to create the custom theme? Which way?
Then, where will I insert the files copied from the Default folder?
