Android
Latest
Hello all, I have a playlist in a layout and then 2 x ticker running underneath. I have 4 playlists in the layout.
I am not sure I have it set up quite correctly…
I want it to run along the lines of:-
Team brief content to be the primary playlist.
Safety, Did you know, General to be fillers and spread out randomly amongst the team brief playlist. Does this look setup correctly?
Also when it gets to the end of the playlists, the whole screen flashes and the tickers, clock and static images all reset and start again…is there a way I can make unconnected regions just loop not affected by the main region running out?
thanks in advance.
