A new problem with xibo 1.8.12 and win client.
If I select now in the design “TEXT” and there copy something purely, Xibo does not show me everything
here are some screenshots.
Can you tell me why I can not do this anymore?
I just look at version 1.8.12 you always have to click “Apply” and then “SAVE”.
This is how it is and will take over.
Greeting
Sorry, I´m again. When i make a layout with text an there i will copy a graphic…the graphic is not displayed
what can i do? in xibo 1.7.5 this is always going…
Kussel
In 1.8 you need to insert images from the Library using the top right Library search menu:
You can then right click on the inserted image to access image properties to tweak size and positioning.
Also ensure that your region is sized appropriately to ensure that your text and images fit within the region border.
If trying the above does not solve your issue, then please do come back to us.
Thank you
ahh ok you have to know that first … thank you
it works now!!
