Connecting my TV
Hello everyone,
How can i connect my TV in order to use Xibo? Is using a player the only way to? Or is there any other way to do it?
Thank you.
This is very serious, please reply to me.
That would depend on the TV, if it’s some kind of smart tv like the Samsung series with pre-installed Samsung digital signage software, then you definitely can’t install Xibo on it, I’m not certain if it allows some android/windows box to be connected to it either.
If it’s not so smart tv, then you should be able to connect PC/android box to it via hdmi and make it display signal from that device,
