hello.
im trying Xibo out for the first time and im trying to set CMS 1.8 up and running on Ubuntu 16.04 x64.
everything goes well until i get to the point where i need to Edit the config. im a noob and i need help to edit these configs.
this is what i’ve done so far (btw i know i’ve screwed up a major part of those configs ) :
MYSQL_PASSWORD=
SMTP Server Hostname
CMS_SMTP_SERVER=smtp.gmail.com:25
SMTP Username
CMS_SMTP_USERNAME=MYEMAIL@gmail.com
SMTP Password
CMS_SMTP_PASSWORD=MYPASSWORD
Use a TLS Connection YES/NO
CMS_SMTP_USE_TLS=NO
Use a STARTTLS Connection YES/NO
CMS_SMTP_USE_STARTTLS=NO
Rewrite domain (the domain your email will appear to come from)
CMS_SMTP_REWRITE_DOMAIN=gmail.com
Hostname that we should identify ourself to the remote server as
CMS_SMTP_HOSTNAME=gmail.com
Can the From line be overridden in the outbound email
NB GMail will rewrite the From address anyway so it’s not important
for GMail - YES/NO
CMS_SMTP_FROM_LINE_OVERRIDE=YES
It is sometimes necessary to configure the webserver running inside
the container to know the DNS name by which you will normally
access the CMS. For most installations this is unnecessary and can
be left as default, however, if you know this, it won’t hurt to
set it
CMS_SERVER_NAME=cms.example.org
i’ve done the above changes but im Encountering the following error :
Fatal Error - sorry this shouldn’t happen. SQLSTATE[28000] [1045] Access denied for user ‘cms’@‘172.18.0.4’ (using password: NO)
What should i do differently?
