I installed the new CMS version (1.7.6) and created new users after the upgrade. With users created after the upgrade can not log in, I insert the correct user and password but the login page does not load the dashboard and looping.
Always loading login page…no errors!
Permissions are correct, all users are in a group named “Spot” where they are set correctly. Users created before the upgrade don’t have this problem …
You will want to enable global debugging on your CMS (Report fault page -> turn on debugging)
try to log in as a user that gives you this problem.
then check ‘Logs’ page for errors
Changing to test mode won’t affect the Players. It will just show any errors directly to the browser and may show additional in the logs too.
So switch to test mode, then try and log in as one of these users, and then log back in as an admin and see if anything was logged. It should at least log the login attempt.
Is that a theme you’ve applied to the CMS or have you edited the CMS code directly?
