I had a quick question regarding the way the CMS and the players communicate. Do all connections between the CMS and Players originate from the CMS? Or are players able to originate connections between the two as well?
All connections originate from the Player. The CMS is able to directly message the Player via XMR, however the connection is opened and persisted from the Player side to avoid issues with NAT traversal and firewalls.
Ok, Thank you very much.
