Hello
I configured XMR for showing screenshots and sending commands. The player says XMR status: connected (tcp://IP:9505).
But when I want a screenshot from the client or sending a command I’m getting this CMS error (I switched to test mode for the server to see errors):
I’using Xibo 1.8.2 on Win 2012 Server with Apache webserver and PHP 5.6.30.
What’s wrong?
alex
2
It looks like you’re missing the OpenSSL module from your PHP installation.
It might just be case of enabling it in the php.ini file.
If so, please let me know so I can log a bug so that we check for it as part of the install/upgrade process.
Wow, that was easy
Thank you very much for your fast support
alex
4
Thanks for the feedback.
I’ll get a bug logged so we’re checking for that at install time.
