CMS language should change the language of HELP_BASE
Just a remark, I have seen that the provided manual folder (HELP_BASE) is prepared for different languages, while it is independent from the CMS language setting. It is not too bad, since one does not change language every while, and also a different target or path could be used. But maybe a user could expect that changing the CMS language would also change the help language (if available, of course).
As said, not too bad, but maybe something to think about (a check box to add or not the language code to the manual path?).
