I just upgraded my CMS from 18.9 to 2.01. I went through the process and started up CMS, but I am not getting a response from the port I have configured. Docker is running, but how do I check if the container is working correctly? What other ways can I troubleshoot my issue?
The CMS can take some time to start up, especially on Windows, or if you have incorrect XMR configuration.
docker-compose logs -f
Will give you the log output from the containers. If it says configuring or running maintenance, then you need to give it more time, and when it has started, double check the XMR private port configuration - particularly if this was a CMS install that started outside Docker and was imported at some stage. If it has always been Docker then it shouldn’t be wrong.
Here is the output of the logs…
cms-web_1 | Waiting for MySQL to start - max 300 seconds
cms-web_1 | MySQL started
cms-web_1 | settingId
cms-web_1 | 1
cms-web_1 | Existing Database, checking if we need to upgrade it
cms-web_1 | Phinx by CakePHP - https://phinx.org. 0.9.2
cms-web_1 |
cms-web_1 | using config file .varwwwcmsphinx.php
cms-web_1 | using config parser php
cms-web_1 | using migration paths
cms-db_1 | 2019-05-08 20:49:38 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
cms-web_1 | - /var/www/cms/db/migrations
cms-web_1 | warning no environment specified, defaulting to: production
cms-db_1 | 2019-05-08 20:49:38 0 [Note] mysqld (mysqld 5.6.43) starting as process 1 …
cms-web_1 | ordering by creation time
cms-web_1 |
cms-db_1 | 2019-05-08 20:49:38 1 [Note] Plugin ‘FEDERATED’ is disabled.
cms-web_1 | Status [Migration ID] Started Finished Migration Name
cms-web_1 | ----------------------------------------------------------------------------------
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: Using atomics to ref count buffer pool pages
cms-web_1 | up 20180130073838 2019-05-08 19:49:30 2019-05-08 19:49:30 InstallMigration
cms-web_1 | up 20180131113100 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep85Migration
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: The InnoDB memory heap is disabled
cms-web_1 | up 20180131113853 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep86Migration
cms-web_1 | up 20180131113941 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep87Migration
cms-web_1 | up 20180131113948 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep88Migration
cms-web_1 | up 20180131113952 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep92Migration
cms-web_1 | up 20180131113957 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep120Migration
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
cms-web_1 | up 20180131114002 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep121Migration
cms-web_1 | up 20180131114007 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep122Migration
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: Memory barrier is not used
cms-web_1 | up 20180131114013 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep123Migration
cms-web_1 | up 20180131114017 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep124Migration
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: Compressed tables use zlib 1.2.11
cms-web_1 | up 20180131114021 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep125Migration
cms-web_1 | up 20180131114025 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep126Migration
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: Using Linux native AIO
cms-web_1 | up 20180131114030 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep127Migration
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: Using CPU crc32 instructions
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: Initializing buffer pool, size = 128.0M
cms-web_1 | up 20180131114050 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep128Migration
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: Completed initialization of buffer pool
cms-web_1 | up 20180131114058 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep129Migration
cms-web_1 | up 20180131114103 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep130Migration
cms-web_1 | up 20180131114107 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep131Migration
cms-web_1 | up 20180131114110 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep132Migration
cms-web_1 | up 20180131114114 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep133Migration
cms-web_1 | up 20180131114118 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep134Migration
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: Highest supported file format is Barracuda.
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: 128 rollback segment(s) are active.
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: Waiting for purge to start
cms-web_1 | up 20180131114123 2019-05-08 19:49:30 2019-05-08 19:49:30 OldUpgradeStep135Migration
cms-db_1 | 2019-05-08 20:49:38 1 [Note] InnoDB: 5.6.43 started; log sequence number 47602835
cms-web_1 | up 20180131122645 2019-05-08 19:49:30 2019-05-08 19:49:31 OneRegionPerPlaylistMigration
cms-db_1 | 2019-05-08 20:49:38 1 [Note] Server hostname (bind-address): ‘’; port: 3306
cms-web_1 | up 20180131123038 2019-05-08 19:49:31 2019-05-08 19:49:31 PlaylistTagsMigration
cms-db_1 | 2019-05-08 20:49:38 1 [Note] IPv6 is available.
cms-web_1 | up 20180131123248 2019-05-08 19:49:31 2019-05-08 19:49:31 WidgetFromToDtMigration
cms-db_1 | 2019-05-08 20:49:38 1 [Note] - ‘::’ resolves to ‘::’;
cms-db_1 | 2019-05-08 20:49:38 1 [Note] Server socket created on IP: ‘::’.
cms-db_1 | 2019-05-08 20:49:38 1 [Warning] Insecure configuration for --pid-file: Location ‘/var/run/mysqld’ in the path is accessible to all OS users. Consider choosing a different directory.
cms-db_1 | 2019-05-08 20:49:38 1 [Warning] ‘proxies_priv’ entry ‘@ root@176db46e4a58’ ignored in --skip-name-resolve mode.
cms-db_1 | 2019-05-08 20:49:38 1 [Note] Event Scheduler: Loaded 0 events
cms-db_1 | 2019-05-08 20:49:38 1 [Note] mysqld: ready for connections.
cms-db_1 | Version: ‘5.6.43’ socket: ‘/var/run/mysqld/mysqld.sock’ port: 3306 MySQL Community Server (GPL)
cms-db_1 | 2019-05-08 20:59:12 1 [Note] mysqld: Normal shutdown
cms-web_1 | up 20180212143336 2019-05-08 19:49:31 2019-05-08 19:49:31 DaypartSystemEntriesAsRecords
cms-db_1 |
cms-web_1 | up 20180213173846 2019-05-08 19:49:31 2019-05-08 19:49:31 MailFromNameSettingMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Giving 0 client threads a chance to die gracefully
cms-web_1 | up 20180219141257 2019-05-08 19:49:31 2019-05-08 19:49:31 DisplayGroupClosureIndexToNonUnique
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Event Scheduler: Purging the queue. 0 events
cms-web_1 | up 20180223180534 2019-05-08 19:49:31 2019-05-08 19:49:31 DataSetColumnFilterAndSortOptionsMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down slave threads
cms-web_1 | up 20180302182421 2019-05-08 19:49:31 2019-05-08 19:49:31 WidgetCreatedAndModifiedDtMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Forcefully disconnecting 0 remaining clients
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Binlog end
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘partition’
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘PERFORMANCE_SCHEMA’
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_SYS_DATAFILES’
cms-web_1 | up 20180313085749 2019-05-08 19:49:31 2019-05-08 19:49:31 MediaTableEditedIdIndexMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_SYS_TABLESPACES’
cms-web_1 | up 20180320154652 2019-05-08 19:49:31 2019-05-08 19:49:32 PlaylistAddDynamicFilterMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_SYS_FOREIGN_COLS’
cms-web_1 | up 20180327153325 2019-05-08 19:49:32 2019-05-08 19:49:32 RemoveUserLoggedInMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_SYS_FOREIGN’
cms-web_1 | up 20180514114415 2019-05-08 19:49:32 2019-05-08 19:49:32 FixCaseOnHelpTextFieldMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_SYS_FIELDS’
cms-web_1 | up 20180515123835 2019-05-08 19:49:32 2019-05-08 19:49:32 LayoutPublishDraftMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_SYS_COLUMNS’
cms-web_1 | up 20180529065816 2019-05-08 19:49:32 2019-05-08 19:49:33 DataSetTruncateFixMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_SYS_INDEXES’
cms-web_1 | up 20180529073531 2019-05-08 19:49:33 2019-05-08 19:49:33 DisplayAsVncLinkMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_SYS_TABLESTATS’
cms-web_1 | up 20180621134013 2019-05-08 19:49:33 2019-05-08 19:49:33 AddWidgetSyncTaskMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_SYS_TABLES’
cms-web_1 | up 20180621134250 2019-05-08 19:49:33 2019-05-08 19:49:33 EventLayoutPermissionSettingMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_FT_INDEX_TABLE’
cms-web_1 | up 20180906115552 2019-05-08 19:49:33 2019-05-08 19:49:33 AddForeignKeysToTagsMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_FT_INDEX_CACHE’
cms-web_1 | up 20180906115606 2019-05-08 19:49:33 2019-05-08 19:49:34 AddForeignKeysToPermissionsMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_FT_CONFIG’
cms-web_1 | up 20180906115712 2019-05-08 19:49:34 2019-05-08 19:49:34 AddForeignKeysToWidgetMediaMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_FT_BEING_DELETED’
cms-web_1 | up 20180906131643 2019-05-08 19:49:34 2019-05-08 19:49:34 ForgottenPasswordReminderMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_FT_DELETED’
cms-web_1 | up 20180906131716 2019-05-08 19:49:34 2019-05-08 19:49:34 DataSetRssMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_FT_DEFAULT_STOPWORD’
cms-web_1 | up 20181011160130 2019-05-08 19:49:34 2019-05-08 19:49:36 SimpleSettingsMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_METRICS’
cms-web_1 | up 20181113173310 2019-05-08 19:49:36 2019-05-08 19:49:36 RemoveFinanceModuleMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_BUFFER_POOL_STATS’
cms-web_1 | up 20181113180337 2019-05-08 19:49:36 2019-05-08 19:49:36 SplitTickerModuleMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_BUFFER_PAGE_LRU’
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_BUFFER_PAGE’
cms-web_1 | up 20181126113231 2019-05-08 19:49:36 2019-05-08 19:49:36 Release1812Migration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_CMP_PER_INDEX_RESET’
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_CMP_PER_INDEX’
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_CMPMEM_RESET’
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_CMPMEM’
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_CMP_RESET’
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_CMP’
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_LOCK_WAITS’
cms-web_1 | up 20181210092443 2019-05-08 19:49:36 2019-05-08 19:49:36 RemoveImageUriModuleMigration
cms-web_1 | up 20181212114400 2019-05-08 19:49:36 2019-05-08 19:49:36 CreatePlayerVersionsTableMigration
cms-web_1 | up 20181217135044 2019-05-08 19:49:36 2019-05-08 19:49:36 EventSyncMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_LOCKS’
cms-web_1 | up 20190121092556 2019-05-08 19:49:36 2019-05-08 19:49:36 PlayerUpgradeAndOverrideConfigMigration
cms-web_1 | up 20190125170130 2019-05-08 19:49:36 2019-05-08 19:49:36 PlayerSoftwareVersionFieldMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘INNODB_TRX’
cms-web_1 | up 20190129103831 2019-05-08 19:49:36 2019-05-08 19:49:37 AddLinuxDisplayProfileMigration
cms-web_1 | up 20190212115432 2019-05-08 19:49:37 2019-05-08 19:49:37 AddDefaultTransitionDurationSettingMigration
cms-web_1 | up 20190213162212 2019-05-08 19:49:37 2019-05-08 19:49:37 AddHorizontalMenuSettingMigration
cms-web_1 | up 20190220165703 2019-05-08 19:49:37 2019-05-08 19:49:37 AddScheduleRecurrenceMonthlyRepeatsOnMigration
cms-web_1 | up 20190227101705 2019-05-08 19:49:37 2019-05-08 19:49:37 MakeDisplayLicenseColumnUniqueMigration
cms-db_1 | 2019-05-08 20:59:12 1 [Note] Shutting down plugin ‘InnoDB’
cms-web_1 | up 20190228120603 2019-05-08 19:49:37 2019-05-08 19:49:37 AddDynamicCriteriaTagsMigration
cms-web_1 | up 20190301115046 2019-05-08 19:49:37 2019-05-08 19:49:37 AdjustGenericfileValidExtensionsMigration
cms-web_1 |
cms-db_1 | 2019-05-08 20:59:12 1 [Note] InnoDB: FTS optimize thread exiting.
cms-web_1 | cp: can’t stat '/var/www/cms/ca-certs/.pem’: No such file or directory
cms-db_1 | 2019-05-08 20:59:12 1 [Note] InnoDB: Starting shutdown…
cms-web_1 | cp: can’t stat ‘/var/www/cms/ca-certs/.crt’: No such file or directory
cms-web_1 | WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping
cms-db_1 | 2019-05-08 20:59:13 1 [Note] InnoDB: Shutdown completed; log sequence number 47613304
cms-web_1 | Removing web/install/index.php from production container
cms-web_1 | Starting cron
cms-web_1 | AH00558: httpd: Could not reliably determine the server’s fully qualified domain name, using 172.19.0.4. Set the ‘ServerName’ directive globally to suppress this message
cms-db_1 | 2019-05-08 20:59:13 1 [Note] Shutting down plugin ‘BLACKHOLE’
cms-db_1 | 2019-05-08 20:59:13 1 [Note] Shutting down plugin ‘ARCHIVE’
cms-web_1 | 1
cms-db_1 | 2019-05-08 20:59:13 1 [Note] Shutting down plugin ‘MRG_MYISAM’
cms-web_1 |
cms-web_1 |
cms-db_1 | 2019-05-08 20:59:13 1 [Note] Shutting down plugin ‘MyISAM’
cms-db_1 | 2019-05-08 20:59:13 1 [Note] Shutting down plugin ‘MEMORY’
cms-db_1 | 2019-05-08 20:59:13 1 [Note] Shutting down plugin ‘CSV’
cms-db_1 | 2019-05-08 20:59:13 1 [Note] Shutting down plugin ‘sha256_password’
cms-db_1 | 2019-05-08 20:59:13 1 [Note] Shutting down plugin ‘mysql_old_password’
cms-db_1 | 2019-05-08 20:59:13 1 [Note] Shutting down plugin ‘mysql_native_password’
cms-db_1 | 2019-05-08 20:59:13 1 [Note] Shutting down plugin ‘binlog’
cms-db_1 | 2019-05-08 20:59:13 1 [Note] mysqld: Shutdown complete
cms-db_1 |
cms-db_1 | 2019-05-08 21:00:44 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
cms-db_1 | 2019-05-08 21:00:44 0 [Note] mysqld (mysqld 5.6.43) starting as process 1 …
cms-db_1 | 2019-05-08 21:00:44 1 [Note] Plugin ‘FEDERATED’ is disabled.
cms-db_1 | 2019-05-08 21:00:44 1 [Note] InnoDB: Using atomics to ref count buffer pool pages
cms-db_1 | 2019-05-08 21:00:44 1 [Note] InnoDB: The InnoDB memory heap is disabled
cms-db_1 | 2019-05-08 21:00:44 1 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
cms-db_1 | 2019-05-08 21:00:44 1 [Note] InnoDB: Memory barrier is not used
cms-db_1 | 2019-05-08 21:00:44 1 [Note] InnoDB: Compressed tables use zlib 1.2.11
cms-db_1 | 2019-05-08 21:00:44 1 [Note] InnoDB: Using Linux native AIO
cms-db_1 | 2019-05-08 21:00:44 1 [Note] InnoDB: Using CPU crc32 instructions
cms-db_1 | 2019-05-08 21:00:44 1 [Note] InnoDB: Initializing buffer pool, size = 128.0M
cms-db_1 | 2019-05-08 21:00:44 1 [Note] InnoDB: Completed initialization of buffer pool
cms-db_1 | 2019-05-08 21:00:44 1 [Note] InnoDB: Highest supported file format is Barracuda.
cms-db_1 | 2019-05-08 21:00:45 1 [Note] InnoDB: 128 rollback segment(s) are active.
cms-db_1 | 2019-05-08 21:00:45 1 [Note] InnoDB: Waiting for purge to start
cms-db_1 | 2019-05-08 21:00:45 1 [Note] InnoDB: 5.6.43 started; log sequence number 47613304
cms-db_1 | 2019-05-08 21:00:45 1 [Note] Server hostname (bind-address): '’; port: 3306
cms-db_1 | 2019-05-08 21:00:45 1 [Note] IPv6 is available.
cms-db_1 | 2019-05-08 21:00:45 1 [Note] - ‘::’ resolves to ‘::’;
cms-db_1 | 2019-05-08 21:00:45 1 [Note] Server socket created on IP: ‘::’.
cms-db_1 | 2019-05-08 21:00:45 1 [Warning] Insecure configuration for --pid-file: Location ‘/var/run/mysqld’ in the path is accessible to all OS users. Consider choosing a different directory.
cms-db_1 | 2019-05-08 21:00:45 1 [Warning] ‘proxies_priv’ entry ‘@ root@176db46e4a58’ ignored in --skip-name-resolve mode.
cms-db_1 | 2019-05-08 21:00:45 1 [Note] Event Scheduler: Loaded 0 events
cms-db_1 | 2019-05-08 21:00:45 1 [Note] mysqld: ready for connections.
cms-web_1 |
cms-web_1 | cp: can’t stat ‘/var/www/cms/ca-certs/.pem’: No such file or directory
cms-web_1 | cp: can’t stat '/var/www/cms/ca-certs/.crt’: No such file or directory
cms-web_1 | crontab: can’t open ‘/etc/crontabs/apache’: Permission denied
It’s running as normal then.
docker ps
will show you what ports are mapped where. Check that the CMS is listening on the port you expect:
alex@alex-desktop:~$ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
65446161ce34 xibosignage/xibo-cms:release-2.0.1 "/entrypoint.sh" 8 days ago Up 9 hours 0.0.0.0:80->80/tcp xibodocker_cms-web_1
In my case there, it’s listening on port 80 on all interfaces.
Mine is running on 8081. I have my cms_custom-ports.yml configured for 8081 and I started Docker using this file. Contents of my file…
version: “2.1”
services:
cms-db:
image: mysql:5.6
volumes:
- “./shared/db:/var/lib/mysql”
restart: always
environment:
- MYSQL_DATABASE=cms
- MYSQL_USER=cms
- MYSQL_RANDOM_ROOT_PASSWORD=yes
mem_limit: 1g
env_file: config.env
cms-xmr:
image: xibosignage/xibo-xmr:release-0.7
ports:
- “65500:9505”
restart: always
mem_limit: 256m
cms-web:
image: xibosignage/xibo-cms:release-2.0.1
volumes:
- “./shared/cms/custom:/var/www/cms/custom”
- “./shared/backup:/var/www/backup”
- “./shared/cms/web/theme/custom:/var/www/cms/web/theme/custom”
- “./shared/cms/library:/var/www/cms/library”
- “./shared/cms/web/userscripts:/var/www/cms/web/userscripts”
restart: always
links:
- cms-db:mysql
- cms-xmr:50001
environment:
- XMR_HOST=cms-xmr
ports:
- “65501:8081”
mem_limit: 1g
Contents of the ports query…
64a234f3a730 xibosignage/xibo-cms:release-2.0.1 “/entrypoint.sh” 20 hours ago Up 19 hours 80/tcp, 0.0.0.0:65501->8081/tcp xibo_cms-web_1
66a7eb9aab73 xibosignage/xibo-xmr:release-0.7 “/entrypoint.sh” 20 hours ago Up 19 hours 50001/tcp, 0.0.0.0:65500->9505/tcp xibo_cms-xmr_1
85c9e7bbd384 mysql:5.6 “docker-entrypoint.s…” 20 hours ago Up 19 hours 3306/tcp xibo_cms-db_1
Any ideas why this is not working???
