Installation Method
Upgrade from custom 4.3.1 to docker 4.3.1
Operating System
The operating system the CMS is installed on
The upgrade is a success. I used the cms_custom-ports.yml to first test on 8080 and then I switched to 80. Well, I encounter now one issue: subfolder shared/cms/library doesn’t 1) seems to have been copied in the container 2) is not in sync at all with the container.
For what I thought, this shared/cms/library folder should be the one were all my media are. I suppose this since in this page: Upgrade Xibo for Docker Install | Xibo Digital Signage , the first paragraph states that when you upload a file to the library using the web interface, I should get a copy at that place. When I upload a file, it is not, but I can find it in /var/lib/docker/overlay2/c6a462cfc2808cbd2f700ed81ab49a0a1bd9130316dc1b24fc9bd4dbbed1c0ea/diff/var/www/cms/web/shared/cms/library/ and /var/lib/docker/overlay2/c6a462cfc2808cbd2f700ed81ab49a0a1bd9130316dc1b24fc9bd4dbbed1c0ea/merged/var/www/cms/web/shared/cms/library/ . I’m not a pro of docker but it seems normal: I suppose this is the local fs of the container.
To solve my issue 1), I copied manually the files from my old media library to the one folder which stays when you docker compose stop . This seems to be a success: all media are now back to the displays.
I am using Debian Trixie and I believe my situation will be an issue if I try to upgrade to 4.4.0 . I didn’t found how the link between my docker install folder and the container should form. Can you help?
