CMS 3.2.2 - Calendar dates are wrong
Hi!
I think the date are not “calculated” the good way.
Today is shown as “Sunday 12th”, but we are monday.
Also, if I check the box “Hide Weekend days”, it will hide “Friday + Saturday”.
Please fix this issue.
Hi, could you first check that your timezone and language settings have been set correctly in the CMS.
If they are correct, could you give further details as to the settings you have configured for the Calendar Widget (with screenshots if possible) so that we can attempt to recreate the issue you are experiencing.
Thank you
Hi Natasha,
As shown in my screenshot, it is the good year and month (December 2022). But the dates aren’t ok. We are thursday but the calendar shows a wednesday.
Timezone seems fine :
I just figured something :
As I wrote, the calendar shows December 2022, but it seems that the calendar displayed is 2021.
I don’t know if it helps you to figure out where the issue is.
This does not seem to be a general issue as we have been unable to recreate the problem you seem to be experiencing using your settings. We would suggest upgrading to the most recent release CMS 3.3.1 first and see if the problem still persists. If it does then please do let us know if this is a Cloud/Docker or Other instance.
Thank you
I went to “Administration > Modules > Calendar” and wrote “ics” as a valid extension.
I also did a “Verify All” and now everything works as intended. Thanks again!
