CMS 2.0.1 not saving changes in Display Settings
Hello!
After upgrading CMS to version 2.0.1 I found out that changes I made in Display Settings for Windows player profile aren’t been saved. I put check mark on “Enable Power Point” and I tried to configure screen offset to make xibo player able to play on second screen. Also after upgrade, offset settings were been reset.
I’ve tried to override profile settings in Display, put correct values, but player is constantly appears on Primary display, so override doesn’t work either.
Could you please help.
Thank you!
An issue has been identified and logged:
https://github.com/xibosignage/xibo/issues/1779
Thank you
