Cms 1.8.2 on web server third party not save preferences
Hello, I have installed a cms 1.7.9 on a third party web
server (linux, php5.6) works correctly. I have now
installed cms version 1.8.2 on the same server and can
not save when I make new preferences or layout changes.
Could you help me with this?
Thank you very much
chris
Do you see any error prompt on Save?
If not, please go through Report Fault Wizard - ie enable debugging, recreate the issue, check Logs page.
If you do not see related error, then you can save the log file and send it to me via private message.
