There is no entry in the agenda. Whether the player is playing I have not tried.
Best Regards
Hubert
Best Regards
Hubert
Since it is a daypart, logic to me would be that it should not span over midnight. you would need to create two daypart schedules, 16:00 - 23:59 (or 24:00 if it takes it that way) and the other 00:00 - 01:00. End result should be what you want, but keeps in within the 24hr day. @Peter, is this correct?
-Lance
Picture 1 -> End Time:
Enter the end time for this daypart. If the end time is before the start time, then the daypart will cross midnight.
I do agree that dayparts crossing midnight are not working correctly now.
We’ve discussed it internally and we do believe that intended functionality should allow for dayparts to cross midnight - I’ve created a bug report to look into that.
As it is now, if you’d like dayparts to cross midnight, then as Lance has said, you’d need two dayparts from x to midnight and from midnight to y.
