Clocks not working on any layout
Hi All,
After using XAMPP for a while I’ve gone ahead and installed the CMS onto an IIS server for a more permanent home.
Everything appears to be working fine on the server but for some reason the client is not displaying any clock that is available as standard within Xibo. Everything else appears to work fine - I didn’t have this issue when using XAMPP.
Does anybody have any ideas how this could be resolved?
From the Modules page, click the Verify All link.
Then allow the Player some time to download the extra files and the clock should start working.
Done! :slight_smile: Also found this at the same time - Clock, embedded regions don't show on Windows XP player
Thanks for your help :slight_smile:
