Clock module missing 1.7.4
I have two 1.7.4. instances and one had the clock module and the other does not. I have run ‘Verify’ modules but it does not show up.
Has it been disabled in the modules list? CMS -> Modules -> Find Clock -> Edit -> Enable.
It doesn’t appear in the list of modules so I can’t enable or disable it.
Can someone check on this instance?
I am anxious to get the clocks working because I am moving to android displays.
If the module is missing completely, I would reinstall. Double check the file and folder permissions before the reinstall.
Yeah, in ‘normal’ circumstances that would be the way to go.
I’ve contacted John via pm, we had a look at his CMS instance, since it’s hosted with us, we were able to fix it.
Clock module is back!
Ah, I did not know it was a hosted version.
