Clients not updating after layout update
we are heavily configuring layouts and content for our information system.
Following the documentation, i thought changing a layout would trigger the clients to update the layout right away (< 1 minute).
This seems not to work, Only removing a layout from the campaign and adding it again seems to trigger the displays updating the layouts.
Regards
Jens
Indeed there seem to be an issue with updating layout flag if it’s assigned to the campaign, which results in the delay between your change in CMS and player showing it, it is possible to ‘work around it’, by simple doing edit&save on either campaign or display profile.
We are aware of this issue, it is logged here - https://github.com/xibosignage/xibo/issues/1300
Hi Peter,
thanks for the reply. Is there a scheduled release date for 1.8.3?
We will have some “not very technical” authors working with XIBO in the near future.
Regards
Jens
