Currently i’m working on the local server.
How do I set up the the client credential in the “application” form?
You just save the “add” form, and then open the “edit” form - and they are there.
If you really have /web in the URL, then that implies an issue in your CMS configuration.
Please see here http://xibo.org.uk/manual/en/install_environment.html (documentRoot and URL rewriting).
also grant_type should be client_credentials
as that’s most likely what you’re using.
