Client startup error
New to Xibo, struggling to get Client to display anything I create, is it due to this?
Status
"Client found response content type of ‘text/html; charset=UTF-8’, but expected ‘text/xml’.
The request failed with the error message:
(tried to paste in error code but failed, anyone know the way to paste the code in without affecting the message?)
Yes it’s due to that. It sounds to me like you have the wrong address entered in the Player settings for the CMS.
It should be the same address you use to access the CMS Admin console - so if you were hosting on Xibo Cloud that would be something like https://instance.xibo.co.uk
If you’re hosting on your own server then you should hopefully know where you installed Xibo to, and the appropriate DNS name to use to connect to the server.
Very greatful for the quick reply, I manged to fix by adjusting the .PHP.
Terrific application, will be encouraging the Director to donate to the Project.
