Good morning
as you can see from the images sequences it’ seems that the client have no sability about content sability…
The sequence was made in consecutive times with a narrow lapse of time between the screenshots.
Between screenshots noone have modified layouts or scheduling.
Does anyone have any idea why this happens?
Does noone have any ideas?
What do you think exactley. Can you explain you Problem a littel bit better?
Greetings Torsten
Yes sure… I try…
I mean that the cloud simble means that the client wait to be updated…
Some second after the client connct server and download update
After this client remain update for few second and return in “wait for update”
In the meantime noone have done any modify to scheduling or layouts…
In the following screenshot you can see what happens within a few minutes. All clients are connected but require continuous updates.
Uploa ding: image.png…
