Client player resolution seems off but should not
Ok, here is what I have :smile:
  • CMS 1.7.4
  • A resolution of standard 1920x1080
  • A client with that resolution on a monitor with that resolution
  • A layout with that specific size
  • A simple image of that spefic size
Still, it shows like zoomed in on the client (I only see the upper left part, like 2/3rd of it…
I’ve been to the defaultconfig.xml and hardcoded the 1920 and 1080 values… still no luck.
Any idea ?
Here is the Original
And the result
The original is the actual file on the server. The result is a print-screen of the xibo client. Both have the same resolution (1920x1080), so the image is stretched somewhere…
Hi David,
That’s odd, image looks fine (resolution/dpi wise) and it was correctly displayed on my Windows player
I assume you also have 1.7.4 Windows player, correct?
Basically I created simple layout, with 1 full screen region (1920x1080) and uploaded your image and it seems to be fine.
When you test it, does it look the same in CMS preview?
Good morning. In fact, I think it was my laptop+additionnal display that was causing the issue. I did use another pc with dual DP monitors 1920x1080 and it worked well. Case closed :wink:
Thanks a lot!
