Clear Cached Data as Command?
is it possible to get the “Clear Cached Data” option as a command?
Found under: Display->Edit->Advanced->Clear Cached Data
Currently it is not possible to send a Clear Cached Data command. If you feel this is a feature that would be helpful in future releases, you are welcome to suggest it in the Features section of the Community Forum:
https://community.xibo.org.uk/c/features
