Hi guys,
is there any ways of increasing character limitations of
- Templates
- Layouts
- Playlists
- Players
It is very hard to use describing names when there is limitation of only 50 characters.
It would be great to increase to 100, is there any way to achieve this somehow?
Thanks!
Could you give some examples of the sorts of names you want to be able to use? Half a dozen or more such examples?
Hi Baylink,
thanks for the response.
Not sure why you are asking examples, the idea is to be able to use more than 50 characters while naming layouts, templates, playlists and players, it does not matter what we are typing.
The name could be for example “Quick fox jumps over the hedge but fails to catch the chicken because chicken was way too fast to catch”
I was politely suggesting that it’s very likely that there’s a good naming protocol you could use that wouldn’t bust 50 characters. But nevermind…
Sorry Baylink!
i didn’t mean to be rude.
“it’s very likely that there’s a good naming protocol you could use that wouldn’t bust 50 characters”
There are no good naming protocols which can always do what is needed. 50 characters are not enough always.
