Changes forbbiden when accessing with a different fqdn
I have an existing Xibo 3 docker installation working fine locally since some months.
Now I have published this server to extenal network using public ip adress and domain name.
Acess and navigation trought the CMS is ok with server name and public IP.
The issue i’m facing is that when acessing the server using fqdn or public ip, i’m unable to do changes always get the following forbidden message :
when accessing back with the local ip adress used for since installation it is ok to make changes.
Even locally, when using the fqdn pointing to the local ip, the issue is faced again.
Any idea on how to correct this ?
Regards,
