Certification error
Hello!
Hope you guys can shed some light on my issue.
I’m very new to Xibo so bear with me if I sound a little newbie. I’ve managed to setup the Xibo server side of things and that’s all fine (hopefully), I can create layouts, change settings and all that good stuff, but when I try to connect to it via the client PC, I just get a “Page cannot be displayed, make sure 192.168.56.1:85 is correct and try again”, when I enter the IP into the client I get “Unable to connect to remove server” error.
I’ve entered that IP into the web address on the server and it connects fine, I can log in and do bits, but cannot on the client. However, when I use https and port 443, it works but I get a certificate error to which I can proceed, but I cannot schedule displays and they don’t push out or do anything, so I assumed it was the certificate error stopping this? I’m using IIS if that helps at all?
Any info on this would be great!
Thanks,
Ben
I’ve sorted out the issue, no need to worry!
Can delete this thread.
Thanks,
Ben
