since i upgrade from 3.0.6 to 3.0.8 (same with 3.0.7), the CMS doesn’t show the layout content (and some other menu) + error while navigate to parameter (see screenshot)
upgrade instruction :
get the newest tar.gz via wget url
extract tar.gz to a temp folder
chown -R the temp folder (www-data:www-data)
stop apache2
delete older file/folder
copy paste new file/folder
copy settings in web folder
run the phinx script
start apache2
delete /web/install/something.php
i upgrade xibo since years and this is the first time i got a problem
echo $DB
echo “ALTER DATABASE `$DB` CHARACTER SET $CHARSET COLLATE $COLL;” | mysql
echo “USE `$DB`; SHOW TABLES;” | mysql -u usermysql -p’passwordmysql’ -s | (
while read TABLE; do
echo $DB.$TABLE
echo “ALTER TABLE `$TABLE` CONVERT TO CHARACTER SET $CHARSET COLLATE $COLL;” | mysql -u mysqluser -p’mysqlpassword’ $DB
done
i just install 3.1.1 release, and all seems to work fine
