I Have a problem with permissions.
When I log in as a user being part of a user group, In the permissions window I can’t see the other users from my group. I can only see myself and my user group.
I remember it hasn’t always been like this. I should see here all the users from my group.
I must have changed something to get there but I can’t find what.
I’ve tried many different settings with no avail.
Thank you for your message. Can you confirm the User type you are using for this account? Can you also confirm what Permissions window you are in? If you can provide a screenshot of the issue, this would also help so I can attempt to replicate it.
My apologies for the delayed reply to your issue. I have been testing the permissions and I suspect the functionality you are looking for is reserved for the User Type Group Admin. Can you try changing the User type to Group Admin to see if this resolves your issue?
