somehow i don’t manage to get to play what i need at some hours. it looks like it has something to do with scheduling from one day to the next. also the day view shows only till 22:30
do you have suggestions what to do?
What CMS version are you using please?
i’m on the cloud hosted platform
ok I see, 1.8.1.
I don’t think there is an issue with the schedule itself, as events should work exactly as scheduled, I did test that via Postman, events are correctly added to the schedule, but the visual representation on the Day view is not good.
Other views will show it correctly.
In any case I’ve created an issue for that - https://github.com/xibosignage/xibo/issues/1201
Thanks for bringing this to our attention.
