Can't access CMS, everythings running
I have updated Xibo to 1.8.3 for docker, but I can’t get on the CMS-page. The page shows “ERR_EMPTY_RESPONSE”-message.
According to the logs, the webserver is running.
“AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 172.19.0.4. Set the ‘ServerName’ directive globally to suppress this message”
Normally, the IP is 172.17.152.240:8080, with the custom port 8080 instead of 80.
I’ve updated the config.env file, run the commanda docker-compose down and docker-compose up -d.
No errors during this part. But still, after more than 30 minutes, the CMS is still not reachable. Do I miss anything?
Even going back to the previous version is not working anymore, resulting in the same ERR_EMPTY_RESPONSE message. Can anybody help me with this?
what does docker ps -a shows?
If you’re using custom ports then after upgrade you will need to adjust the compose files along with any other changes you’ve made to those files - https://xibo.org.uk/manual/en/upgrade_docker.html
Thanks, it was a small mistake in the configuration of the custom ports.
Instead of 8080:80, I had 8080:8080. Fixing this was sufficient.
