Cannot scroll page after Save Order Layout
As title says. After I reorder any media in layout and press Save Order, then I stuck. I cannot scroll up at layout page, I must close that layout page then reopen it. (Layout Page where add, remove, reorder media, not Webpage CMS).
Any methods to fix it? Thanks.
Regards,
Hieu Nguyen.
What CMS version are you using please?
Also which browser?
Hi Peter,
I use CMS 1.7.8 and not work with Chrome and Microsoft Edge.
Thanks,
Hieu Nguyen
I have noticed this for months.
Peter,
It has to do with Bootstrap and using multiple modals. Focus is not being returned to the open modal that the second modal was opened from. Instead Bootstrap returns the focus to the main window. Multiple modals are not support by bootstrap version 3, and as it looks version 4 alpha.
This might help, look at the last post and the fiddle example:
Right, thanks for the additional details, now we know what the problem is.
I’ve logged it as a bug in current series, it should be fixed in the next release.
Thank you for bringing this to our attention
