Can not see uploaded fonts in Text Editor
Hi all
I’m using CMS and XiboClient Version 1.7.8. I have Uploaded some fonts e.g rockwell, impact and pypats all in tts format but unfortunatley when trying to use them in text editor they’re not there (in fonts dropdown). I have cleared cache several times restarted apache but still no joy.
Can anyone help please ?
Did you ‘install’ your fonts after uploading them? ie edit and save.
http://xibo.org.uk/manual/en/media_module_font.html
after you install them and then clear browser cache, they should be added to the text editor.
Thank you Peter that has solved the problem.
