Campaings problem
Good morning,
I have a xibo docker system that I have been using for 5 years.
It turns out that for a couple of weeks, I try to access “Campaigns” to update the content of the digital signage and it automatically expels me and I have to log in again. This only happens in the “Campaigns” tab. In the other tabs I can navigate perfectly.
I don’t know how I can solve it. Could it be a storage problem?
I would appreciate any help. Thanks.
I have Version 1.8.11 xibo. I see that in mozila firefox the “campaigns” section doesn’t work but instead in chrome this section works correctly. Could someone give me an answer?
Hello and welcome to the Xibo Community.
As v1.8 is no longer supported we would suggest that you upgrade to a supported version:
Thank you
