Campaign Layouts - Repeats and out of Order
Windows Player
Xibo for Docker 2.0.3 - Running on Windows 7
In testing, have created 6 slides; the 6th slide being the default which comes with fresh install of Xibo.
Here’s how they’re configured (5 second durations for each):
Slide 1 - Weather
Slides 2-4 - Background Image with Text
Slide 5 - White background; two regions. Left region Image, Right region Text
Slide 6 - Default with background
Created new campaign (Schedule Now -> “Always” checked and a Display Group selected for Display) and configured it to display the layouts in order of slides 1 through 6 without any repeats or loops of slides.
First time, this is how they played:
Slide 1 - Plays twice
Slide 6 - Plays once
Slide 1 - Plays once
Slide 6 - Plays twice
Slide 2 - Plays once
Slide 3 - Plays once
Slide 4 - Plays once
Slide 5 - Plays once
REPEAT BACK TO TOP
Windows Player, cleared the local library and played again. This is how they played:
Slide 1 - Plays three times
Slide 2 - Plays twice
Slide 3 - Plays twice
Slide 4 - Plays twice
Slide 5 - Plays twice
REPEAT BACK TO TOP
Why is this occurring?
So removed the campaign and re-created a new campaign using the same layouts; Slides 1 through 6.
On the windows player, cleared the local library and connected to the server.
REPEAT BACK TO TOP
Fresh day and updated Xibo to 2.0.4.
On Player PC (running latest windows player on Windows 10), the slides ran as follows:
REPEAT BACK TO TOP
Thank you for your messages and updates on the Playback of your campaign.
So to clarify I have understood the issue correctly, you have created a Campaign that will show your Layouts 1-6, in order without repeating?
If you go to the schedule option in your CMS, click the Select Displays box above the Calendar and choose your Display. The calendar will now populate with icons for all scheduled Events. Can you check if there are any other Layouts/campaigns scheduled for that Display or is it only the Event you have set with your Campaign, set to show always? If you are only supposed to be showing the Campaign, there should only be 1 Event per day on your Calendar.
I also noticed that in all cases, the order the does not appear to be changing. They seem to play 1,6,1,6,1,2,3,4,5,6, can you also confirm that your Campaign only has Layouts 1,2,3,4,5 and 6 included?
Please also confirm the version of the Xibo for Windows player you are using.
