Campaign Issues 403 forbidden nginx
Having a issue with layouts in campaign. If i set a layout as a default layout within displays it works perfectly, once i add that layout into a campaign i get 403 forbidden nginx? The layout is a webpage: https://www.flightradar24.com/simple
Any reason why this would happen.
James
I’m not sure why would that happen, either way it’s the same layout, added to schedule in a different way, but still it’s the same webpage and the layout playback should be the same.
Could you please tell us when and where exactly do you see this error message?
Peter,
The error appears if the layout is campaign mode and on the player. The CMS plays the campaign fine. And if I set it default layout and no campaign is set it’s also plays fine through the player. The issue is that layout in campaign displaying on player.
James
