Hi all,
I have a Philips meeting room display with LEDs and Xibo Player V 3-300, connected to a 3.0.1 CMS. I use the trigger of the calendar widget to switch the LED color. It works fine for the trigger “No Event” (LED green), but not for “Current Event” (LED red). It’s not a problem with the command or action. It looks like that even there is an event, the trigger “No Event” is executed. During an event, I used “send command” to switch the LED to red, but they switch back to green the next minute.
In the calendar widget I use a template for “current event”, so I know that the player detects the current event. Any idea?
