Calendar not updating
I’m trying to pull a Wordpress calendar from ceyorks.org/posts/events the calendar loads fine. But once I start adding more events they do not show. Is this a caching issue? And if so how can I stop this. I would like it show the new event as soon as the calendar region is shown
It could be yes, or the duration on your layout perhaps.
If you’re using Windows client, then you might want to check IE Internet Options -> Settings (under browsing history) -> select ‘Every time I visit the webpage’.
Peter,
That hasn’t worked
James
Is it updated if you preview the layout in CMS?
Are you using webpage or embedded html modules to show it?
Do you have a long durations on your layout?
Peter,
I does update in preview on CMS, I’m using webpage and the duration is 60sec.
thanks
James
