Calendar Module without "Templates" tab
Version 3.1.0
Windows 10 Client
Include the full version, including the revision number.
The calendar Module, dont show the Templates Tab
I already try with Chrome and Edge.
Thanks,
Hi Antonio_Viana, welcome to the community!
The calendar widget has changed compared to previous CMS versions. Please can you try the Agenda widget and confirm if this is what you are looking for? That has the templates option for formatting the events in your calendar link.
Thanks for the solution. Sorry for the late feedback.
:ok_hand:
