Hi
I set up calendar module and try to understand how the event dissapear ?For example i put event 9AM to 10AM and when it s 10H01 the event don t dissapear, it will dissapear at 11AM.
Can you explain me ?
Hi
If you open the Layout containing the Calendar, Edit the Calendar Widget and select the Advanced tab, you should see the Update Interval
field. Can you confirm what this is set to in your Widget please?
I put value 1 for 1 minutes ?
May be the time off my xibo server is not Good ? how can i change it ?
It s ok now i miss the regional setting so now i put the good timezone and all is ok
Thanks for help
