Bug while create new or copy a existing remote dataset (xibo 2.0.4)
While create a new remote dataset or copy a existing remote dataset a error occurs.
2133,0894f7d,"2019-07-31 13:11:20",WEB,/dataset/copy/2,POST,"SQLSTATE[42000]: Syntax error or access violation: 1110 Column 'lastClear' specified twice Exception Type: PDOException",,ERROR
Creating a local dataset and switch it afterwards to remote works fine.
Version: xibo version 2.0.4 as docker image
Thank you for your post.
This is a known issue as reported here: Bug while create new or copy a existing remote dataset (xibo 2.0.4) which has been added to the 2.0.5 milestone.
Thank you
