[BUG] Creating regions
Dear Xibo Staff,
Another unexpected behaviour from the CMS (maybe? I’m not sure on this.)
Anyway if you move a region, or resize, and you decide to create another one without saving first, the previous moved/resized region will be back at his size, or position, forgetting your edits.
Francesco
I’ll move your topic to the Support, as again, that’s not a feature request.
It is also not a bug, you need to save current region positions in current layout designer, otherwise it will reset that when you add new region / leave designer page.
Ok… so It’s a developer choice :slight_smile: sorry again :blush:
