Trying to use the multi-select on dataset rows in Version 2.3.10.
Once rows are selected, I try to ‘Delete selected rows’ using the button at the bottom right but it doesn’t do anything. No errors in the Chrome console either - just nothing happens.
This issue was also present in previous versions of the CMS - but this is the first time reporting it.
Let me know if you need more info.
